Results 1 to 5 of 5
Thread: Recommendations Please.
    Electrician Terry Ray's Avatar
    May 2010
    Washington State
    Red face Recommendations Please.
    Ok the water test show the water coming out of my well are:
    3.5 gpg Hardness
    0.35 Iron
    6 PH
    We are having issues with stained laundry,occasional yellowish bath water,and sometimes the wife says the water smells.
    Our Home is approximately 3000 SQ Ft. 21/2 Bathrooms
    The plumbing to the house is 1.25" CPVC
    The Well and pressure tank is out in the shop about 150' from the house
    We have the following plumbing fixtures:
    1 large soaking tub
    1 regular tub
    1 dual head shower
    1 single head shower
    3 Toilets
    4 bathroom sinks
    1 kitchen sink
    1 faucet over the cooktop
    1 dishwasher
    1 washing machine
    1 water heater
    It is not uncommon for all three showerheads to be running at the same time as well as washer running too!
    I could probably live with the 3.5 hardness but my wife wants very soft water (and lots of it)
    I could use recommendations as to what kind of system should be used for our home that would be low maintenance and high quality.
    Thanks in Advance,
    Dec 2009
    Alaska
    You will need to find either a neutralizer or soda ash injection to correct the ph from the 6.0 to 7.3
    After that you could use a softener to remove the hardness.. most likely a unit that has 1.5 cubic foot or 48K max capacity.
    May 2010
    Washington State
    What about the iron?
    Will the softener deal with that?
    Dec 2009
    Alaska
    The iron level that you have is almost NOT there... staining level is .3ppm and you say you have .35ppm.... and if your neutrilizer is calcite then the iron could most likely be removed by it.
    If there is iron after bringing the ph up then it should stay low and well with range of most good quality softeners.
    I my self would stay away from Box Store systems and deal with a local company, the main reason if a challenge happens it is most likely to happen on a weekend.
    Box Stores sell but no back up, internet is great but if you need help by some one coming out to work on the units that most likely will not happen.
    May 2010
    Washington State
    We do have staining and our iron is a little over .3 ppm.
    Sorry if I wasnt clear
  1. Air Jet Tub Recommendations?
    By Flannery in forum Shower & bathtub Forum & Blog
    Last Post: 11-09-2011, 10:00 AM
  2. 1.28 GPF recommendations
    By buckler in forum Toilet Forum discussions
    Last Post: 01-08-2009, 03:45 PM
  3. Recommendations and help, please...
    By crosby1 in forum Shower & bathtub Forum & Blog
    Last Post: 01-07-2008, 07:00 AM
  4. Looking for recommendations on a new tub
    By plumbbob in forum Shower & bathtub Forum & Blog
    Last Post: 11-11-2006, 06:38 AM
  5. PRV Recommendations
    By jk60 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-26-2006, 03:36 PM
