You put the cleanout at a height were it will be convenient to access it. Your joists should be a 16" o.c. so if you are only crossing 3 of them, you should be within the limits for the toilet opening. As long as there is not a second story above this bathroom using that vent pipe as a drain, you should be okay, assuming you actually install the piping the way you have it drawn.
