Results 1 to 11 of 11
Thread: Fridge Water Line Connection
    DIY Junior Member bobloblaw's Avatar
    May 2010
    Seattle, WA
    Default Fridge Water Line Connection
    I have 1/4 inch PEX to the rear of the fridge. How do I connect the PEX to the fridge fitting which is a 1/4 inch copper compression fitting?
    The make an insert that prevents pex from crushing when used in a compression fitting. The insert goes inside the pex.
    May 2010
    Seattle, WA
    Hi Terry,
    The problem i have is the OD of 1/4 inch PEX is 3/8. The fridge compression fitting is for 1/4 od copper. So I need to transition from the PEX to either 1/4 inch copper or 1/4 inch stainless flex line. I should note that I need an additional 4 feet of line from the end of the PEX to the fridge
    Bob
    why not install an icebox valve in the wall then connect the fridge line to that. you can find a plastic box with valve at any big box store for about 25.00, then you can shut the water off at the fridge if you ever need to move it.
    The icebox connection is the way to go all right.
    Get the one with the water hammer arrestor, otherwise the tubing will be moving quite a bit everytime the ice tray finishes filling.
    May 2010
    Seattle, WA
    I like the ice box connection but the walls are built.
    I should have mentioned the 1/4 inch PEX is coming from a 3/8 OD compression ball valve at the sink. The fridge is 10 feet away. Brass Craft list an ice maker connector 240 inches long with a 3/8 compression x 1/4 compression connectors Part Number B1-240IM. This connector would solve my problem but calls to three plumbing supply houses and Brass Craft brought no joy. Anybody know where i might get this part?
    Bob
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    This may also be difficult to locate, but another option is an adapter from 3/8" female compression to 1/4" compression. The Larsen number is 17-6754, but may also be available from other distributers. You could also change the valve under the sink to one with a 1/4" compression outlet.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Or you could just get a 3/8" comp. X 1/4" comp. Brass union and connect the two ! !
    But be sure to use the inserts TERRY posted about ! !
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    A 3/8 x 1/4 compression union/coupling, and a 60" 1/4x1/4 stainless steel flexible connector and a 1/4 x 1/4 compression coupling at the refrigerator.
    Default Icemaker box
    Where would I get one of these. I have checked all of the big box stores around and none of them have the one with the hammer arrestors.
    Thanks,
    Jim
    http://www.ipscorp.com/watertite/sup...imoutlethammer You could search on IPS corp, or call a plumbing supply house.
