Results 1 to 10 of 10
Thread: How to judge tightness of threaded connections
Hybrid View
    DIY Junior Member WendyH's Avatar
    Apr 2010
    Maple Grove, MN
    Default How to judge tightness of threaded connections
    My new Moen shower valves have female threaded ports. I am sweating male adapters to my pipes and then connecting to the valves. I then have further sweat connections between valves and to the supply lines and shower heads. I won't be able to really test for water tightness until the system is complete, but by then I won't be able to disassemble the threaded connections. How can I tell if they are correctly tightened? Is it possible to overtighten? The connections are rigid copper to brass, 3/4", no compression. I'm using tape on the threads.
    It would be almost impossible to overtighten, unless you are a 600# gorilla. There is NEVER any guarantee that the connections will not leak, regardless of WHO tightens the thread. That is why few plumbers use the valves with threaded connections.
    Many (not all) valves with threads will also act like a fitting (i.e., the pipe will fit inside the valve) and you can solder it. Because the valve body is bigger, it will take longer to reach soldering temperature and can transfer heat to the guts, so it is often recommended to remove the guts while soldering. This is a more reliable method, if available.
    quote; Many (not all) valves with threads will also act like a fitting (i.e., the pipe will fit inside the valve) and you can solder it
    That is only true for those valves with a mip connection. FIP connections ALWAYS require a threaded fitting attached to them.
    Apr 2010
    Maple Grove, MN
    I just got home and checked. The pipe fits into the valve, but it seems to be quite loose (but a coupler is too big to fit). Plus the females are giant thick brass beasts. I imagine they would be hard to heat and require a ton of solder. And then I'd worry about solder running into the valve itself. I'm thinking that the chicken way is the best for this amateur. I'm also thinking that I could probably use our compressor and some plugs to pressurize the pipe and then bubble test the threaded connection. I don't imagine it would take too much pressure.
    For a belt and suspenders thing, use both the dope and the tape. If the tap was getting a little dull, it can tear the threads and make it hard to seal with just one - it won't hurt to use both.
    DIY Junior Member K.'s Avatar
    Jul 2007
    Ontario
    While it's certainly true that pipe threads are not guaranteed to be watertight without the right amount of dope and/or tape, you can at least be certain about how many turns to make. All tapered thread specs have an 'engagement' spec which tells you the overlap between the two parts when fully tightened. You can convert that into a number of turns by using the threads per inch spec.
    -Jonathan
