Results 1 to 10 of 10
Thread: Torque (getting it right)
Hybrid View
    experienced amateur rerickson's Avatar
    Apr 2010
    Puget Sound
    Question Torque (getting it right)
    How do you estimate (or measure) torque on connector screws?
    Put another way: how do you teach an apprentice what the correct torque feels like?
    I discover I over-tightened some screws on the grounding bus bar of our panel; one #12 was crushed beyond flat. On the other hand, I'm going to be using some Al connectors that call for 35 and 50 in-lb. So it's time to get my torques right.
    Could buy (or perhaps rent) an automotive torque wrench, but there's probably a better way...
    Thanks much for all your advice! Reading this forum has been very helpful.
    P.S. All of these use a slotted drive. I will use emery paper and Noalox on the Aluminum.
    Quote Originally Posted by rerickson View Post
    He has to learn how to feel the wire tightening in the lug.
    Let him do it then check his work.
    Automotive torque wrenchs are NOT calibrated in inch pounds they use foot pounds. Practice and experience is the best teacher, and most users would have stopped twisting LONG BEFORE the ground wires were "beyond flat" whatever that means. It is like putting stuff in a box. You may be able to put a lot of stuff into it, but that does not mean you can carry it, or that the box will not fall apart when you try. Just because you have a big enough screwdriver to keep twisting it, does NOT mean that it is not tight.
    The safest thing is to buy a torque screwdriver...they are readily available.
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    Even Sears has torque wrenches calibrated in inch/pounds. Or you could convert foot/pounds to inch/pounds.
    Nov 2009
    VA
    If you go with a torque wrench, you will want a mini one. You are looking at a torque of 3-5 ft-lbs. Common automotive torque wrenches are 0-150 ft-lbs (or more), so they aren't that accurate for these low torque values. In addition, the handles tend to be long on most automotive torque wrenches, so not great in small spaces.
    So, look for a torque screwdriver or a mini torque wrench. One that is calibrated in in-lbs is more likely to better suite the range of torque values that you need.
