BrooklynDIY
Hello all...this is my first post on this forum. I have searched extensively and I think I found a post with a similar answer to this one, it wanted to make sure I was correct that I can do this before I proceed.
The drain enters my sink base from the right hand side of my sink and relatively low...Perhaps a maximum of 5 inches off of the bottom of the cabinet. Essentially this means that if I run the drain pipe straight down from the sink, into the p-trap and out to the stack that I have no room under my sink.
I read a post that sounded like it was possible to make a 90 degree elbow immediately after the drain exits the sink...then run horizontally to the side and then another 90 degree elbow vertically down to the P-Trap.
I have attached my attempt to diagram this solution... Please let me know if this is acceptable. Also, would It also be possible to still run my dishwasher drain hose into the vertical section of the drain pipe...
BrooklynDIY
BrooklynDIY
