call a plumber. think of your family
In a bathtub/shower remodel, I was trying to replace the 3/4" galvanized end to 1/2" copper reducer from the galvanized pipe coming from the hot water supply when the galvanized pipe broke right above the threads of a rusty T. The pipe to the left of the T comes from the Hot Water Tank & is undergound & the pipe to the right of the T supplies downline & is also under concrete. There is no crawl space. House is on a concrete slab. The work area I have to work with was previously dug out (by the previous owners) & there may be just short of a foot of galvanized pipe partially exposed on the right side of the T & even this is bordered by concrete on the edge closest to the exterior wall. Is there any way to re-route to avoid having to deal with the pipes under the concrete? As you can probably tell I'm an amateur. Is there a way to "plug" up the hole? Even if the whole pipe was exposed, I still wouldn't know the best way to proceed. If I have to get to the pipes, how would you recommend I proceed? If hiring a plumber is my best bet, I guess I'll have to bite the bullet & pay the costs.
Any help would be greatly appreciated since we don't even have water at this point.
Post a picture or two and I'm sure someone can recommend an option or three for you.
Thx
Jason
Old galvanized is probably the worst type of pipe to work with. You cannot solder it, so you have to get to good threads. You can try very carefully cutting and chiseling out the remaining stub in the T. This is not easy work and may not even be possible given the rust you have already encountered. How old is the house?
