The trick is not to use the True Value PTFE paste on the threads but rather on either the male or female part of the union.. when one undoes the union nut there are two parts, the part that has the threads that the nut screws on to and the other part that the nut stays with. With both parts clean , put a small amount of paste on either one, does not matter which, but doing so will put a seal between the two metal parts and has worked 99 out of 100 for me.. a trick that I learned years ago from an old time plumber that told me about that trick after telling him about the challenge of getting a union to stop leaking...even with 2 of the largest pipe wrenches and lots of pressure they would not seal... now with just a little paste on one of the two parts ,, 2 normal size and light pressure and life is great..
