Thread: Drain pipe not verticle
    DIY Junior Member chuck49286's Avatar
    May 2010
    Lansing, MI
    Default Drain pipe not verticle
    I’m replacing the subfloor & flange in a 35 year old addition after the old one leaked & rotted out. I Got it set up & was dry fitting everything when I found that one side of the flange was about 1/4 inch above the floor when the other side was flush. That’s when I determined that the drain pipe wasn’t vertical. I’ve discovered the Souix City brand “Push Tite” flange which looks like it would allow me to correct the angle.
    Notes: It’s all PVC, & the drain has two 45 degree angles in the first 24 inches.
    Any suggestions?
    Do these type of (I’ll call them “gasket” flanges) work well, and last a long time?
    Thanks for your help
    Here is a link to Sioux City. You can explain your problem this them and get a straight answer.
    chase.wagner@siouxchief.com
    May 2010
    Lansing, MI
    FYI
    I emailed Chase Wagner 5 days ago & haven't heard back.
    With all the experts on this forum I'm hoping for an independent opinion of this product.
    Thanks again
    Chuck
    Sorry you didn't get a reply from the email. Seems stupid they would include a personal email address in the website and not monitor it at least occasionally. I'm also surprised that some of the true pros on this forum haven't chipped in. You might try talking to a large plumbing supply house in your area. Don't give up on us, getting no response is not the usual here.
