Results 1 to 2 of 2
Thread: piezo ingnitor generator did not generate starkling after replacment of Anode
    DIY Junior Member
    Apr 2010
    PA
    Default piezo ingnitor generator did not generate starkling after replacment of Anode
    I just changed the gas water heater anode. I do not know why the piezo ingnitor generator did not generate starkling. Thanks.
    The most common reason is that the wire is exposed somewhere and is shorting out to the tank. Or, the wire is loose. Or, the electrode is not positioned properly next to the pilot burner. Or,........................ But it had nothing to do with your changing the anode rod. If you had not turned off the gas to the heater, you would still have had the problem you just wouldn't have known about it because you would not have had to relight the pilot.
