Thread: Leaking sprinkler heads
    DIY Junior Member L84toff's Avatar
    Apr 2010
    Brantford
    Default Leaking sprinkler heads
    Hey folks,
    When I went to start our sprinkler system this spring, I discovered that both our sprinkler heads on the same zone are leaking. I find it very strange that both would have a leaking problem all of a sudden at the same time. We had the system blown out last fall.
    We have been doing some landscaping and although we've been careful not to step on either of them, it's possible someone did.
    We've been in the house about a year and a half but had no problems with the opening or running of it last year.
    The leak itself is at the top, appears to be coming from where the water normally comes out from when it's running. The head does not appear to be all the way down as I can press it down and the leak stops, at least for a moment or two. I've unscrewed the top part and hosed it all off, thinking there may be some debris stuck in it. But after replacing it, the leak continues.
    I was going to replace the heads with new ones, but like I said, it seems strange that both heads in the same zone have gone at the same time.
    Any suggestions would be greatly appreciated.
    DIY Member
    Jun 2009
    northeast
    The valve that supplies water to those two heads is probably stuck open. It may be something lodged between the diaphragm and seat, or maybe a worn or pitted diaphragm seat. A tiny leak at the valve diaphragm will cause water to dribble from the top of a head, usually most notable at the lowest head on the line. Easy to fix if your handy. Remove top portion of the valve and check for obstructions, and or a pitted diaphragm seat. Be carefull during disassemble as there is a spring in there that should not be lost. Also do not forget to shut the water off first.
    Apr 2010
    Brantford
    Dumb question edited.
    That's exactly what it was. Problem appears to be fixed.
    Thanks very much.
