Results 1 to 7 of 7
Thread: How do I unthread pipe from a fitting?
    DIY Junior Member awardmont's Avatar
    Dec 2009
    houston texas
    Default How do I unthread pipe from a fitting?
    Hello all , new to forum, I cant seperate ( unscrew) a 1/2" galvanized water pipe from its 90 connection, any tips? i have a seyt or ridgid manual threaders, but prefer not to use it.
    Thanks mike,
    Yakima WA
    You need two pipe wrenches. One to turn the pipe, the other to provide counter pressure on the elbow. If the joint is too tight, you risk the possibility of egg shaping the elbow, and if you do, then you will have to remove the elbow and replace it. PB Blaster might help. Apply it, let it set for awhile before applying pressure.
    I sometimes throw a little heat on the fitting, not the pipe.
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    A shot of rust buster, WD-40, or magic snake oil of your choice, tap the fitting many, many, many times with a hammer, heat per Terry (optional), two wrenches with pipe slid over them for cheaters, throw in a blast of your best French adjectives and pull steady while praying.
    Nov 2009
    Victor, MT
    Oops, mis-read 1/2" to be 1 1/2". Cheaters optional, English adjectives will suffice.
    Yakima WA
    FYI: WD-49 is great stuff for many things, but it is not a very good penetrating oil. PB Blaster has become a favorite although there are other good products that will work pretty well, too.
    In the Trades ilya's Avatar
    Dec 2009
    Akron Ohio
    Gary's right-wd40 is no good as a penetrating oil. PB Blaster is very good, and kroil is even better. Heat the fitting as Terry said, and as it expands it tends to break up the rust. Cool it off some so the oil won't cook, and oil it up. Go to lunch. Oil it again. Call your girl and flirt, but not so much that you have to leave the jobsite-you should've handled that at lunchtime.Dont heat after oiling-you'll just burn the oil. 2 14" pipe wrenches should do it.
    not a licensed plumber
