Thread: Remove Iron from pipes
    DIY Junior Member waterworld's Avatar
    Apr 2010
    South Carolina
    Default Remove Iron from pipes
    First of all Hello.
    I am thinking of installing a softener for my house and was wondering how to remove the iron from the inside of my PVC pipes or should I even be concerned with this?
    Dec 2009
    Alaska
    Most of the time after a softener or iron filter goes it the treated water will clean out the inside of the pipes, ie the build up will go back into the water because the water does not have the iron thus pulling the iron back into the water from the build up inside the pipes. This might take a few days or a week or two depending on the amount of iron that has been in the water and the age of the place in question.
    Apr 2010
    South Carolina
    Thanks for your reply. Do you clean the pipes when installing new systems for new customers?
    Dec 2009
    Alaska
    I will use new to cut in the system from the current pipes, but the rest will stay. Now the pvc or cpvc might stay stained, but iron bleed off as the clean water starts to flow could take a few days or up to 2 weeks as reported by my customers around here.. Your case will be different, but the iron in the current lines and water heater should get less as the usage and days go by.
