trizoyd
In the last two years I've replaced the pipe line from the well to my house twice, replaced the foot valve about 3 times, 3 water pumps and one pressure tank.
Last year I placed a brand new pipe line from the well to the house, new foot valve and new water pump. The pump would run fine for a day or two, and then when we use the water the pump would run at 15psi and it wouldn't build it's pressure. I've noticed during this time that there is an air bubble in the pipe that goes from my pump to the pressure tank. To fix this issue I'd shut the pump off and start it back again, and then air bubble would pass.
I also have a check valve, so I'd never lose my prime. This problem occurs mostly in the morning when we run the washer, flush the toilet and use the shower. Two days ago my water pump finally burnt out (I think it was running all night and I didn't here it.). So yesterday I purchased a new water pump and pressure tank (Goulds), and it seemed to work just fine. This morning as we are doing our normal morning activities, I noticed no water pressure and could here the pump running. Once again the air bubble is there and the pump is not gaining it's pressure, so I have to shut it off and on and then it works fine.
It appears that perhaps the foot valve is not holding water in the pipe. So overnight when the water is not being used, the water seeps out causing an air pocket in the line, and when the pump starts up in the morning it's taking the air in, causing it to lose pressure.
I'm running out of ideas, and before I dig the trench for a 3rd time in two years any suggestion would be great!
Troy
Troy
