lorunner1213
- Messages
- 6
- Reaction score
- 0
- Points
- 0
Ok I have a strange thing going on here. I have my well pump outside down in the hole. from what I can see the piping comes in through the foundation and goes into what looks like a check valve of some kind. Than it goes to a T where there is a gauge that is currently stuck on 60 PSI. from there it T's to the reserve bladder tank and than it T's one more time into a Square D pressure switch that sends power up to a Franklin solid state switch control.
The problem is this. When im in my laundry room I hear what sounds like a faucet is open and water is flowing coming from the pipes above. What I have found is that when i go to my well resivoir where that gauge is and the valve It sounds like its coming from there. However no valves are open and no faucets are on adn the toilet isnt even running. So I took the cover off the Square D switch and the 4 contacts arent touching. So at that point I checked for voltage and obviousely I have none. But if i manual close those contacts for a second and than open them the noise stops. Until you use the water in the house and the pump runs again to fill up the pressure. Than it starts all over.
The noise is kinda like a hissing but from the bottom of the blue resivoir tank. The best way I can describe it is if you open the kitchen faucet just a hair and you hear the water coming out.
Could it be the check valve is bad and or sticking?
Thanks in advance, Jeff
