Results 1 to 8 of 8
Thread: Need help identifying a Moen 1200 shower valve/cartridge
    DIY Junior Member sproksch's Avatar
    Apr 2010
    Virginia
    Question Need help identifying a Moen 1200 shower valve/cartridge
    Hello Ė can anyone help identify my Moen shower cartridge/valve (photo attached)? It just says Moen on the valve but there are no numbers anywhere. I emailed Moen but they haven't gotten back to me.
    The cartridge is fine, but what I need is a trim kit that will fit this cartridge. The previous trimís knob would just turn completely around and not stop at hot or cold. Pretty annoying, so I thought Iíd try and fix it by finding the appropriate knob and trim. But itís pretty hard when you can figure out the model of your cartridge/valve.
    If I canít figure out the valve model, is there a generic trim kit/knob out there that might work?
    Name:  moen valve..jpg
    The "stop" for the handle is IN the HANDLE, so if it keeps rotating you either do NOT have the chrome "stop tube" slid over that brass part of the valve, or you have a handle for a lavatory faucet. I am not sure that your "cartridge is okay" anymore, since you have pulled the center piece out of it. There are several companies that make new trim for your valve, you just have to be sure that the two anchor screw holes in the round plate are both below the handle opening, not one at the lower left and the other at the upper right. IF you put everything back together properly, all you need is a new TUB/SHOWER handle which Home Depot and many hardware stores carry, but also ensure that it is not for a "positemp" valve which uses a different handle altogether.
    Plumber jimbo's Avatar
    You have removed the shank-only of a standard Moen 1200 brass cartridge. It takes standard Legend or Chateau trim ( make sure to specify trim that is NOT for positemp or moentrol.)
    There is not a huge variety, but you can get a brushed nickel or even oil rubbed bronze escutcheon, to go with the teardrop shape acrylic pull-out type handle.
    The two ears you see at the top and bottom of the opening are the main part of that cartridges, and you need to get a moen cartridge puller to try and loosen that up and pull it out.
    Moen 1225B cartridge
    Apr 2010
    Virginia
    Thumbs up
    ah ha! I think you guys nailed it. I think someone had remodeled this with a lavatory handle because it did not have a stop tube; just a handle and a rubber sleeve that formed a seal.
    And thanks for tip on the cartridge. I thought I had left something of the cartridge behind - I've replaced a couple of cartridges in the past but they've always come out in one piece. So, when I just pulled the shank out of this one, I thought maybe I was just dealing with a weird old cartridge.
    thanks again!
    Steve
    The Moentrol DOES use the 1200/1225 cartridge. The stop tube is NOT part of the handle, it is the stainless steel piece that slides onto the valve before you install the handle, (you do have one, don't you?). A lavatory handles DOES have the stop, but it is in the wrong location when used as a tub/shower handle.
    Apr 2010
    Virginia
    Understood - a stop tube was not installed on this whenever someone remodeled it. All they had was the escutcheon, a round knob/handle, and a rubber sleeve that provided the seal around the knob. I can see that this plastic knob has what looks to be stops as part of the molded plastic, but I'm guessing that this would fit a lavatory faucet.
    I'm thinking I need a whole new trim kit that includes an actual shower handle, stop tube, and escutcheon.
    The Moentrol DOES use the 1200/1225 cartridge. .
    My point was that the escutcheons are not the same...similar...but not necessarily interchangeable. His is not moentrol....I don't see he spool in the pics.
    Apr 2010
    Virginia
    Just finished buying and installing the Chateau trim kit - it fits great and everything seems to be working! The cartridge seems ok after I put the stem back in. Hopefully it'll last me a while longer.
    Thanks again for everyone's help! The old lady is happy!
    Steve
  1. Moen Shower Cartridge Removal Tool
    By HawkeyeSean in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-10-2013, 06:23 AM
  2. Identifying Tub Shower cartridge, Source for the BNK7005
    By Old man in forum Shower & bathtub Forum & Blog
    Last Post: 05-15-2013, 03:32 PM
  3. Identifying Cartridge, Moen 1200
    By kalisti in forum Shower & bathtub Forum & Blog
    Last Post: 05-06-2012, 05:18 PM
  4. Moen 1200 cartridge - can I just replace the rings??
    By nards01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2012, 05:14 AM
  5. Advice and Help Identifying Mixet Shower Valve Cartridge
    By shonuff66 in forum Shower & bathtub Forum & Blog
    Last Post: 12-31-2005, 08:48 PM
