Results 1 to 10 of 10
Thread: Adding switched receptacle
    DIY Member Bassman's Avatar
    Aug 2006
    Ventura, CA
    Default Adding switched receptacle
    I have a switched duplex receptacle that has a black and white wire connected to it. It seems that if I want to add another switched receptacle across the room, all I would need to do is connect another run of 2-wire to this receptacle and the 2nd would be switched as well. Is this the correct way to do it? Thanks for your help.
    Neil
    That would be one way to do it. It depends on where the switch is in relation to the currently switched receptacle whether it is easier to run it from the switch or the receptacle.
    Most of the time, half of the receptacle is switched, and the other half is powered constantly, but it doesn't have to be done that way - both could be switched. If they are separate, then one or both of the tabs would be broken so each could be controlled independently.
    Aug 2006
    Ventura, CA
    It'll be much easier to run from the existing receptacle. If I get this right, the black wire I have now is part of the switch loop so I can't have one outlet hot and one switched, but that's okay.
    Yes, if both of the tabs are intact, and there's only black/white (and ground, I assume), then there's only the switched power available there. You'd need at least three wires there to have one always hot. If they used that box as a junction, there might be a hot burried in the back of the box you could use.
    Aug 2006
    Ventura, CA
    No ground wires in the original circuits in this house, unfortunately. GFCI at the panel.
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    Without a ground the circuit should not be extended.
    Aug 2006
    Ventura, CA
    Even with the GFCI protecting the circuit?
    Electrical Contractor jbfan74's Avatar
    Jun 2007
    Newnan, GA
    Correct!
    2 wire circuits are not allowed to be extended.
    Yes I am A Pirate-Jimmy Buffett
    But don't lose any sleep over it.
    Aug 2006
    Ventura, CA
    Not a wink.
