Originally Posted by
jadnashua
Since the Wedi panels are somewhat flexible, how straight they are depends on the studs they are attached to. Same thing with Kerdi over drywall...if the wall isn't straight, neither will be straight. You seemed to indicate Wedi would be superior. That has no basis in fact.
If you think this is venom, you need to re-read what I said. Both systems are good, and in my opinion, superior to a conventional shower with liner and cbu. There are other systems that work well, too. Latticrete has a nice surface membrane, and others. Redgard is a good product, but the variability of how it is applied means it takes some skill to get perfect coverage and the required thickness. Most people don't have a film thickness gauge, or know how to use one. You can have problems if it is too thick or too thin, and especially if you have pinholes. Take any two people painting something on, and they will have different results on how thick and consistent the painted film ends up. With Redgard, it is critical to have it fairly consistent and within the specified range of film thickness.
With a surface waterproofing system, the whole shower dries out much faster (which is more important in a hot/humid environment or high use shower) which helps to prevent mildew. In a conventional shower, the walls and pan can and will absorb some moisture and may not dry out in between uses. This can lead to a buildup of moisture.
As with anything, there is some skill involved in installation. Mixing the thinset for use with Kerdi is the bigger issue with it. Getting a good seal at the joints and penetrations of the screws with Wedi is it's weak point, as is generating a good rabbit joint if you need to cut it to fit. Neither is a horrible limitation and a typical moderately skilled homeowner can do it successfully. I think the Kerdi film scares some people, and they don't believe it could work at keeping out moisture on the seams. Wedi seems like it should be more reliable since the seams are sealed with a urethane adhesive. But, tests have proven that in a proper Kerdi seam, water under pressure (i.e. submerged, which isn't normal in a shower), that moisture only penetrates about 1/4", and they specify at least a 2" overlap (800% margin). With Wedi, you do not have anywhere near that margin. Again, both are quite good, and not hard to use. They each have their strengths and weaknesses. At one class I attended, they had a cardboard box covered with thinset applied Kerdi that had been in use as a drink cooler for months. The cardboard was getting soft, not from moisture, but from the constant flexing from the ice turning to liquid and the rummaging in it to find the desired cold drink. If you take a hunk of Kerdi, roll it into a funnel, and fill it with water, even with the pointy end, it will hold water because of its hygrophobic properties. Now, make the joint at least 2" wide and hold it together with thinset, and it is waterproof under pressure (which you don't normally have in a shower). Kerdi works...Wedi works...Redgard works. Understand the system, install it correctly, and you'll have a successful installation.
