My pump, 1 HP Sta-rite, is 100 feet from my house with a frost free hydrant about 10 feet from the well. All the branch lines come next and the tank tee, Pressure switch, 40-60, and the last thing is an 80 GAL Pressure tank.
Franklin says to install the P tank between the pump and P switch in line from the pump to the house, not exactly what I have here! I read the installation directions from Franklin and it says you can change the pin settings if you have a line before the P tank, but all of my lines are before the P tank and the last thing in line is the P tank. I have started to have hydraulic shock or hammering when my under ground sprinkler valves shut off. Not every time but about 3 out of 8 zones and it sounds like the pipes are going to come out of the wall. I stopped by the pump dealer and talked with them about it and they said 2 options, a valve at the bottom of the pump, $200 or the MONODRIVE box, $1000. I would most likely do the MONODRIVE myself and save a little money, but after reading the install directions I now have questions as to if it will work at all?? Any help or ideas would be most appreciated and thanks in advance for all responses.
Lyle Pfeifer
Lyle Pfeifer
