Results 1 to 9 of 9
Thread: Replacing galvanized in a tight space
Hybrid View
    Default Replacing galvanized in a tight space
    My 1928 home has galvanized pipe throughout. I have gutted a half bath on the second floor to repair some old water damage (leaking window, leaking cast-iron toilet flange). While I have the walls and floor ripped out, I would like to replace the galvanized pipe with copper.
    The pipes currently run from the 2nd floor, through an outside wall, to the crawlspace below the first floor. The crawlspace is about 4' tall. The space where the current pipes run is in a box, aproximately 7" x 7".
    My question, is what is the best way to get a new line run from the crawlspace to the 2nd floor?
    I'm assuming I won't be able to flex a 10' piece of rigid copper pipe enough, within the constrains of the 4' crawlspace, to be able to slide it up the wall cavity (or will I?). And it seems soft copper is not code for above ground?
    The walls in the house are plaster over wood lathe, so chopping into them is certainly a last resort.
    Also .. what about supporting the pipe through such a run? Would it be okay to have it supported only at the top and bottom of the ~10' run? (I'm asking this, assuming I'll use rigid copper, as I have another bathroom which I would like to replace the galvanize pipe to as well -- but I have 7' of basement clearance below it.)
    Thanks in advance for the help.
    Default pipes
    You can use soft copper, but one problem with not being able to anchor it except at the top and bottom is that the hot and cold pipes could be touching and any vibtration would cause a "dinging" sound.
    Feb 2005
    Talking tight spacees
    in that situation if it is as tight as
    you claim, you are probably really
    gambling that you will be able to snake copper pipes
    up the wall....
    another approach might be to get a fish tape down that wall
    and then duct tape two pieces of AQUAPEX to the line and pull
    them back up to the second floor together at the same time...
    if its only one bathroom you might be able to just
    do 1/2 wirsbo pex pipe and get by just fine.
    it seems to be very forgiveing that way....
    I dont particularry like the stuff that much,
    but you got to do what you got to do and it will most likely
    last you 20 years.
    then in the crawl space switch it back to copper
    and do the same on the second floor too....
    just make the runs up the wall into pex
    the pex is far more flexible and you might have a decent chance to
    worm them up there.........
    and as HI mentioned you wont get
    that dinging noise in the pipes either.
    you can even duct tape the two pieces of pex together
    all teh way up the wall as you are feeding it up there.
    DIY Member
    Sep 2005
    portland, or
    okay, first off i don't know nuthin' 'bout nuthin'.
    but just to address the issue of getting 10' of pipe up from a 4' crawlspace: couldn't you sweat a coupling onto the end of a 3' section and send it up, then sweat another 3' on, then another etc?
    Feb 2005
    Talking yes you can
    yes you can but god help you if
    one of those couplings deicdes to leak someday
    its best to not give the couplings a chance to
    take its revenge on you after the job is complete
    DIY Senior Member plumguy's Avatar
    Jul 2005
    MA
    Like previously stated I would use softroll copper but slide armaflex(insulation) on it first.
