From what I've read, most inserts do not work well with cutouts. A solid surface one might work. Problem is keeping water getting in back of it around the cutout of the window. Plus, windows typically don't like moisture on the inside! You might want to change the window to a vinal one, then you wouldn't be rotting out the window, but again, it is tough to keep water from teh shower out of the wall. If you want tile ideas on this, check out www.johnbridge.com
