Results 1 to 8 of 8
Thread: Need help to settle a wager: Culligan vs Fleck, Clack, etc.
    Product R&D for a powertool manufacturer dgold's Avatar
    Dec 2006
    Carlsbad, CA
    Default Need help to settle a wager: Culligan vs Fleck, Clack, etc.
    Had dinner with my cousin the other night and the subject of water softening came up. I have a "typical" Fleck 5600 controlled water softening system, with a freestanding 8" resin tank, and a seperate freestanding brine tank.
    He mentioned that I should look at a Culligan -- that they're the best -- and that it would make the water taste better. My initial response, was "it's the same thing." My impression was that they're all functionally identical in terms of how they condition the water -- that as long as they're set up and installed properly, with the proper settings, etc. there's really no big difference between them other than cost, and who provides service (should you need it) down the road.
    Am I right, or is there a real difference in terms of what they do?
    Thanks in advance
    Not a pro, but happy to share my lessons learned whenever I can. This forum has been a fantastic resource along the way.
    Dec 2009
    Alaska
    Quote Originally Posted by dgold View Post
    Thanks in advance
    Functionally softeners are the same, ie media tank, cation resin, control valve (Brand name or Fleck, Autrol, Clack) brine tank.
    It is like 1 ton pickups... Ford or Chevy or Dodge or Toyota or.... the basics are the same.
    But get ready for a firestorm...
    Thanks in advance
    You are right as to what they do; they all use ion exchange (opposite charged particles attract each other) to remove positive charged ions of hardness (calcium and magnesium), ferrous iron and manganese etc. etc. if any is in the water.
    What control valve is used and its quality and its features, ease of repair and parts prices and availability all varies widely.
    In the Trades Wally Hays's Avatar
    Nov 2009
    Good answers gentlemen. Well done.
    Perception is 3/4 of reality
    Dec 2006
    Carlsbad, CA
    Gentlemen,
    Thank you all very much.
    I believe a steak dinner will be coming my way very soon.
    David
    DIY Junior Member David Spivey's Avatar
    Jul 2013
    Indiana
    Thanks in advance
    Almost all softener companies use the same equipment. We are all reselling Pentair Fleck or Clack. Most vessels in our country that are fiberglass are made from Clack and household market share is mostly covered by Clack. Everything over 1" is usually Fleck because Clack has only gone over 1" since 2009.
    The reason I am giving this slight market analysis is because Marlo, Culligan, Enting, and Aquasystems all sell the same stuff and package it just a little differently.
    Kinetico uses their own valve and at a much more expensive cost to the customer. The biggest difference between all of these is simply put... Service.
    Jan 2012
    California
    FYI, Culligan has used Fleck to manufacture many of their valves for decades. The commercial line, 9000, and even variants of the 7000.
    Also, most "vessels" (assuming you mean resin tanks) are Structural Fibers owned by Pentair, not Clack. Pentair is a holding company and owns Autotrol, Fleck, Structural etc. etc. etc.. Now salt tanks would probably be Clack Corp.
    As to the 1"... assuming you mean the internals of a control valve, the Clack WS-1 can service 6" to 21" resin tanks where Fleck, until the 7000 (2005) did not have one 'residential' valve to do that. To connect to larger than 1" plumbing, you simply order the diameter connectors you need. I think the Clack WS-1.25" and 1.5" controls came out much sooner than 2009.
