Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: Fleck 8500 control performs intermittently
  1. #16
    Dec 2009
    Alaska
    Quote Originally Posted by sarrowsm View Post
    After replacing the seals in my Fleck 8500 Control Valve Assy it fails to draw brine. Please note I cleaned out the brine tank, safety valve, and lines. Maybe my control valve needs to be scrapped. Any suggestions?
    Is there any point while it is moving from one part of the cycle to the next that it draws brine?
    Have you checked the injector and screen to make sure that they are clean and in one piece?
  2. #17
    F5Scott sarrowsm's Avatar
    Dec 2010
    Brighton, MI
    Default Fleck 8500 Fails to Draw Brine
    First question - I may have to observe again.
    Second question - I did check both they are clean and in decent shape. The injector bore is discolored compared to other bores.
  3. #18
    Dec 2009
    Alaska
    Discolored should not be a challenge in pulling brine from the brine tank.
    I know that I was having a challenge with an 8500 pulling brine that had the SE control, changed it to the older style and it would pull the brine.
    The SE cam was not stopping where it needed to be to pull the brine and no matter how I changed the microswitches it would not work so I changed to the non SE and it worked great.
  4. #19
    Dec 2010
    Brighton, MI
    Default Fleck 8500
    Please see attachment for diagram of my control.
  5. #20
    Dec 2010
    Brighton, MI
    Default Fleck 8500
  6. #21
    Dec 2009
    Alaska
    Same books I have..
    Could be that the unit is stopping to soon or to late with the switchs and cam to push the brine piston in at the right point for it to draw brine but it will draw brine for a second or two while it is passing that point.
  7. #22
    Dec 2010
    Brighton, MI
    Who was the manufacturer of this powerhead and who sells them? Thank you
  8. #23
    Dec 2009
    Alaska
    Fleck was the manufacturer now known as Pentair.
    Just about any dealer that deals has a supplier that has Fleck/Pentair parts like I do..
    There are some on line that sell Fleck/Pentair parts... I have always seen this as 8500 or twinflo 100..
  9. #24
    Dec 2010
    Brighton, MI
    Default Fleck 8500
    After looking at prices of parts, I'm thinking about replacing the whole system with a Fleck 9000 or Fleck 9100 Water Softener. Some on the online prices are pretty reasonable compared to the parts. Any thoughts on either of these two systems? Thanks
  10. #25
    All you need is a new control valve, your tanks etc. can be reused and you can replace the resin if needed.
    There is no advantage to the brass 9000.
  11. #26
    DIY Junior Member Randy Blodgett's Avatar
    May 2011
    New York
    I have this same 8500 econominder that I have inherited--with no manual. Does anybody know how I could get an instruction manual, or give me a walkthrough on how to program it?
  12. #27
    www.fleckcontrols.com looking for TwinFlo 100e it replaced the 8500 mechanical due to many problems with mechanical indexing failures.
