Results 1 to 10 of 10
Thread: Finding the right tub help?
    DIY Junior Member bowlbug's Avatar
    Apr 2010
    Pacifica, ca
    Default Finding the right tub help?
    There has to be someone out there that knows about bathtubs. I HAVE to redo the bathroom in a house that was built in the 50s. The tub I have now is 60” x 30” x 14” and holds only 9” of water. Here are the problems I am running into.
    With three teenage daughters they all want deeper water. 11”plus has been requested.
    I can not go wider 30”.
    A sales rep has convinced my cast iron is the way to go because 90% of we shower, cast is more stable.
    Last I don’t have 2K to spend on a tub.
    There has to be simple answer to this that I can’t find. The internet is driving me crazy looking for the answer for weeks now. So as a last resort I thought I would ask here. There has to be a good plumber that has dealt with this before.
    Thank you.
    You are dealing with a "reality" here. 30" x 14" high are are a "standard" in tract homes, (before the 60's they were 28" wide but FHA changed its minimum size then.) When you go to 16" high tubs, then you are into a higher level structure and they are always 32" wide. There is almost ZERO demand for a 30"x16" tub, although you might find a specialty manufacturer making a 30"x16" tub, but it will usually be fiberglass or acrylic.
    All the time
    30" wide tubs are 14" high in cast iron.
    http://www.us.kohler.com/onlinecatal...subcategory=26
    You can find cast iron tubs that are 32" by 16-1/4"
    If you need taller, then acrylic or fiberglass in widths of 32" or more.
    32" x 19"
    http://www.us.kohler.com/onlinecatal...ge=0-184588131
    32" x 20"
    http://www.us.kohler.com/onlinecatal...=0--1030269234
    Apr 2010
    Pacifica, ca
    32" has to be the last resort. I just don't have the room without moving a wall. The info the sale rep give about acrylic and fiberglass not being a good idea, is this true? I have found so much contradictory info on the pros and cons of all 3 materials. I have to admit a wood box with a plastic liner is starting to look like a good idea. LOL
    If you want deep, then go for the acrylic.
    Even cast iron tubs show wear after a while.
    Jan 2008
    The tub manufacturers publish the depth to overflow, which is the spec you are interested in.
    I'm really surprised your kids use the tub- I see a lot of homes now with no tub at all.
    Apr 2010
    Pacifica, ca
    There all girls. They LIVE in the bathroom. Thats why I live in the garage.
    DIY Member Agu's Avatar
    May 2009
    Tampa, FL
    Quote Originally Posted by bowlbug View Post
    I had the same issue. After spending hours looking for a "soaker tub" I found it was cheaper to buy a whirlpool tub on sale. To adjust for the 32" tub I cut out the 2X4's and put in a header so the 32" tub fit a 30" opening. If it's not a load bearing wall ( mine wasn't) it's any easy fix.
    Apr 2010
    Pacifica, ca
    Thats would look good. Mine is a load bearing wall. I found a place in fremont, ca that can order something for us. At $1000 for a tub the and i going down to see what he has in mind.
    Apr 2010
    Pacifica, ca
    I have finally found a tub for a resonable price. $531 + tax. It a Maax Modest 60" x 30" x 18" She will hold a little over 12" of water before the over flow. Just thought I would pass on the info for the next person that has the same Question.
