Results 1 to 6 of 6
Thread: Can someone double check my wiring diagram?
    DIY Junior Member dizzo72's Avatar
    Apr 2010
    seatte
    Default Can someone double check my wiring diagram?
    Hi,
    Just wanted a second set of eyes on this wiring diagram. I borrowed most of it from the last figure on this page: http://www.homeimprovementweb.com/in...way-switch.htm
    Credit where credit is due after all.
    Does this seem like a reasonable way to get four fixtures in a long journey without running 3wire the whole length?
    -D
    Reasonable is a relative term.
    I never run the travelers thru the lights. Too many extra splices and you have to take fixtures down to troubleshoot.
    2 wire power at one end, 2 wire switch leg at either end and 3 wire between them is the way to go. Nothing in the fixture boxes except the switch legs.
    DIY Member Lightwave's Avatar
    Aug 2007
    Vancouver, BC
    Be careful with box fill limits for the upper left hand octagon box on your schematic.
    Electrical Contractor jbfan74's Avatar
    Jun 2007
    Newnan, GA
    Like stated above, least complicated way to do the work.
    Yes I am A Pirate-Jimmy Buffett
    Eliminate the run you call #1, and run a two wire, (not 3 wire), cable between the two switches connected to the "traveler" terminals. You have the neutral taken care of in the boxes, so all you need is a "hot" to the first switch from the "fixture #1 box", the travelers between the switches, and the "load" wire from switch #2 to the "fixture #4 box". This will simplify your wiring in the boxes.
    Unorthodox wiring methods rarely simplify anything.
    Keep the power and switch legs in the switch boxes and run a 3wire between them.
