Photo attached...............................
Hi,
I just replaced my vinyl flooring, and miscut at the toilet flange. I don't want water to get under the floor again, is this type of cut typical? Do I need to seal it with silicone or something? Thought a plumber would know, since you guys see toilet flanges more often than I do.
One other problem (and I have read about options, none are fun), the toilet barely touches the floor (cast iron flange) and sits on the flange, the bottom of the flange lacks 1-8 to 1/4" to touching the floor (and it has two layers of sheet and 1/4" luan, still not quite enough). There seems to be a lowered area in the flange (where the lead is) that would hold enough wax to likely seal, but wanted to get opinions on a good fix. Shims, or plastic base? I have seen a base by Oatey, but no one around my area carries it. (One tiolet, have to get it back in service in a few hours). Thanks a lot, I appreciate any advice.
Tom
Hi,
Tom
