Results 1 to 2 of 2
Thread: Two GFCI Breakers in one circuit?
Hybrid View
    DIY Junior Member jmartin's Avatar
    Apr 2010
    Hollister, CA
    Default Two GFCI Breakers in one circuit?
    I am installing an outdoor spa. I have purchased an outdoor sub panel for the spa that includes a 50 amp GFCI breaker. I will be supplying power to this sub panel from the panel in my garage. When I removed the spa from the previous owners home, I snagged the 50 amp GFCI breaker from his sub panel as well. So....
    Would there be a problem if I used his GFCI breaker in my garage panel and the GFCI breaker that is in the new panel also?
    I know that a 50 amp breaker is not that expensive, but I already have one... it just happens to be a GFCI breaker. Can I use them both, or should I toss his aside and buy a standard 50 amp breaker for the garage panel?
    Thanx in advance for your expertise.
    Jim
    Licensed Electrician andrew79's Avatar
    Mar 2010
    Ontario Canada
    shouldn't matter at all to use em both...why buy a straight breaker when you've already got a gfci there. It's a bit redundant but alot cheaper in your case.
