bowhunter195252
What type and size of momentary switch do i need to start a 15 hp 3 phase motor in the construction of a phase converter? The motor draws 28 amps at 240vac. Also ,in wiring the capacitors in parallel ,if the capacitors terminals are not marked positive or negative how do you know which is which? Thanks
