Sixdays
Water well drilling contractor
Hi, I'm a new guy here but have visited this forum many times! I have gleaned much helpful information here as I come across well / pump related problems.
I currently have a customer with a 4 inch submersible well with a water hammer condition upon pump shut-off. The well is 100' +/- in depth with a 30' pumping water level. Pump is set on 1-1/4" pvc and I believe is a 1HP 20GPM nominal (although I have not pulled the pump). The tank is a 80 gallon (equivilant) captive air tank. The well is in the front yard and the tank is about 100' away at the rear of the house. The pressure switch is located in the tank Tee and pipe from well head to tank is also 1-1/4" schedule 40 pvc. Water hammer is noticable in all supply piping including the drop pipe.
What do you all think? I'm assuming that I (likely) have a check valve problem but get confused when I try to visualize what happens when one check valve leaks and there are two in the system. I can viualize that if the check valve at the pump leaks then the water above that point will go to a negative pressure while the "upper" valve holds tank pressure................ However, if the "upper" check valve leaks and the one at the pump holds then I'm thinking maybe this would explain the hammer upon pump shut-off.
The whole check valve discussion is a can of worms I know but I'm a fan of one check valve at the pump although a check valve a the surface is required here (at least on new installations). Would I have any problems with the afore mentioned customer set-up with a single check valve at the pump? What about the pressure switch bouncing ............. any pearls of wisdom?
Many thanks
Teme
Many thanks
Teme
