Jvstevens
I am in the process of remodeling the bathroom on the house I just bought (built in 1958). As far as I can tell, the tub has the original 2 handle Price Pfister tub control. My intent was to replace the valve so as to add showering capability. When I ripped open the "wet wall" to gain access to the valve, I noticed that the PP valve had a 1/2" male brass plug screwed into the top of it. I thought to myself, "A ha! All I have to do is remove this plug and install a shower pipe with head and a new tub spout with built-in diverter knob, and I'm all set! I won't have to replace the whole valve afterall (which would be a pain due to an adjacent vent pipe)! The house designer or plumber must have decided not to install a shower head so as to save money." So, I've done all that, tested it out, and here's what happens:
1) When the water is turned on to a low or medium setting, water flows out the tub spout and everything is fine.
2) When turned to a higher pressure, water starts dribbling out the shower spout, even though the diverter remains in the down position.
3) At full blast, quite a bit of water comes out the shower head. When the diverter knob is pulled up, more water comes out the shower head, but there is still a lot coming out the tub spout.
I started thinking that maybe this valve was not intended to be used in a tub/shower combo mode like I've done. And that the plug was there in case you wanted to use the same valve for a shower (whereby you would install the plug where the tub spout would be instead). If that's the case, is there anything I can do to make this work properly? Or is the new tub spout/diverter defective maybe? It almost works OK, as I've indicated, and I really hesitate to replace the valve, as I've already installed backerboard over the valve. Simple fixes or ideas would be much appreciated!! thanks.
