Yeah I see problems too and believe things are against code. But I don't see enough wrong to cause a full redo now when the guy is installing a new AN filter and water softener.
I did not ever say he had to re-do it. If I did please show me where I did so. ( third time at least I have had to say that)
Since I'm the one debating with you in that thread where you consider you're being beat on, I suppose you will consider this as me beating on you too but it is not intended that way; I consider it a discussion of things that have been said and/or implied to a DIYer doing his own plumbing. Which IMO is why these forums exist.
The OP has thanked me twice for pointing out the plumbing problems.
That thread is 10 pages and 120 posts long, started 2/27/2010 which is 5 weeks ago, and your first post is #107 on page 8 posted on 4/1/2010. IMO mostly all you have done is to be critical and disagreeable with things that I have said; and that started in your first post. Personally I see confrontation and a somewhat anti DIYer attitude in your posts rather than anything helpful to the OP, but that's just me; I do have a lot of experience with confrontational posts by many people that are critical of many things that I say. And the confrontation is not done to help the DIY members that ask for help here.
I am tired of defending this and this entire conversation and furthermore though I may have in the past I now don't give a crap what you think or feel.
And here you've started a thread in the pluming forum about that thread in a different forum by posting the pictures and complaining about someone beating on you. Why do that unless it's designed to be confrontational and stir things up?
Probably because you refuse to read and understand what is said and the replies to your arguments. call it validation.
In that thread you see that there has been no mention of problems with the operation of the drainage system of the house and that the flow from the water treatment equipment is going to be a 3/4" flow for two periods of 15 minutes at say 5 gpm every 3-4 days in the middle of the night for the AN filter and then maybe once per week for the softener at a max 2.0 gpm for part of the regeneration time of roughly 50-75 minutes with 40-60 minutes of that time at roughly only .25 gpm.
If it dripped two drops in two months it would still be wrong. I don't justify plumbing, I do it right.
I don't see a problem with that flow rate and frequency serious enough to talk about redoing just about all the drain lines in the basement including the very ugly cast stack Fernco fitting replacement.
Again for the god knows how many times I NEVER TOLD HIM TO TEAR IT ALL OUT AND RE-DO IT-EVER!!!
For anyone that's interested, here is the link to the other forum's thread starting on the page with your first post in it;
http://www.terrylove.com/forums/showthread.php?35168-Water-Softener-with-RO-and-Ph-%28acid%29-Neutralizer-Install-Help/page8
