Thanks to everyone for your advise, I am a electronic engineer by trade, not a plumber, but have learned a lot from this site. Not sure about the size of the pump, etc. I do have two baths. Also, thanks about the calcite.
When I turned my water on this morning, had almost no pressure, did not look under the crawl space to make sure the pressure guage on the tank was showing pressure, but with a faucet open, and water trickling out of it, I closed the shut off valve that is in line with my cartridge filter and took the filter out and it was completly brown and looked clogged up, it is a charcoal, fine sediment filter that I picked up a lowes.
Put a regualar type filter in and turned the shut off valve on and had pressure, so hoping it was just the fact that the filter was clogged, just not quite so sure why i only had a trickle of water when I turned on the water, wish I had checked the pressure on the tank first. Could it have been because the filter was so clogged up with what I think looks more like brown rust instead of Iron and had sit all night that it would just not let any water pass through.
I will be going out of town for a couple of weeks to work and hoping nothing major could have happened to anything by shocking the well like I did, do really hope it was just a stopped up filter.
Still planning on taking the pressure switch off when I get back in town and make sure the nipple is not clogged, but yesterday the tanks appeared to be turning off and on like it should have, when I watched it, it was a little over 50lbs and had to dropp down to about 30, which seemed like it took about a minute or two to drop down to the 30 and then I could hear the contacts close and the pump turn on, so thinking the nipple is not clogged.
Will check my water first thing in the morning again after it has been turned off all night. The filter I put in this morning is a reqular sediment type cartridge filter and have used the water today and it has a slight light brown tent.
