Thread: cold water surge in re-circ system
    DIY Junior Member Artcraft's Avatar
    Feb 2010
    California
    Default cold water surge in re-circ system
    I replaced a re-circ line for a client, water heater and added uponors demand pump with motion sensors. While showering about five minuits into and at approx recurring intervals the water is not going cold but just going to lukewarm for about 5 seconds and then returning to normal temps. this happens in both showers in the house older non pressure balanced valves. I replaced the line with pex could have the velocity increased due to the smaller inside diameter of the pex and could this be effecting the older valves? Any other thoiughts
    thanks
    DIY Senior Member Jeff1's Avatar
    May 2006
    So Cal
    What is the time interval on the motion sensors?
    Feb 2010
    California
    Once water reaches temp aquastat shuts pump off. does not allow motion to turn it back on untill after the water at the aquastat cools off. I replaced the pump once thinking the intragal check valve was bad, uponor was great to deal with but it did the same thing
    thanks
