Results 1 to 7 of 7
Thread: Double check my plan
    Default Double check my plan
    I have 3 questions.
    First, do i just use a regular 1.5" elbow in the upper right?
    Second, do i just use a regular 2" elbow in the lower left?
    Third, can i use a 2" santee in the bottom right instead of a 2" wye + 45 (store don't got no combos)?
    Oh - and any other problems you see?
    - I just realized, you may want to know, this is for a double bowl kitchen sink.
    Thank you in advance.
    The 2" 90 El below the tee on the left would be a long sweep.
    The 1.5" 90 el on the vent, can be a vent 90 or a med 90
    I normally carry med 90 and long turns, no vent 90'sin the truck.
    They are a fitting that is rarely used.
    Inspectors like to see a 2" cleanout.
    Jan 2006
    Rosedale, Md
    Agree with Terry about the ell and a c.o. If your sink bowls are two different depths make sure you put your rough-in low enough for the lowest bowl.
    Thanks guys, now i just need my third question answered -
    Can i use a 2" santee in the bottom right instead of a 2" wye + 45 (store don't got no combos)?
    All of this is sitting in one stud bay BTW - less than 16" wide.
    Thanks again.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    Yes you could use a santee to make the transition instead of a wye.
    I am curious as to why you are trapping each sink, are you just doing it out of preference or is it code where you are?
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Preference while i have the wall open. I figure it can't hurt. I'm gonna have two sinks, dishwasher and garbage disposal, this makes it easier later i do believe. One sink into wall, disposal into wall, nice and clean.
    Thanks for the help.
    Lont turn elbow on the left, sanitary tee on the right, and a tapped c.o. tee in place of the vent tee. 1 1/2" tapped tee meets the requirement for a full size opening, vent tee does not. Why go to all that trouble? There are easier ways to do it, and I only make multiple inlets when it will be a triple sink.
