Results 1 to 6 of 6
Thread: 3 phase plugs
    DIY Junior Member
    Mar 2010
    Pa.
    Question 3 phase plugs
    On a 3 phase plug. say L15-30ap. the 30 stands for the amps but what boes the L-15 stand for,or L-12, or L-14 when it has the same amperage? Thanks
    Plumber jimbo's Avatar
    The L stands for Locking. The number after the L is the series.
    For example, L12 is 3pole-3Wire, 3ᴓ, 480 V.
    L15 is 3pole-4wire, 3ᴓ, 250 volt
    http://www.hubbellonline.com/wiring/bryant/pdf/h/h3.pdf
    DIY Junior Member
    Mar 2010
    Pa.
    Question 3 phase receptical
    I have a L-14 20p and a L-15 20p, will both of these fit into a L-14 20 receptical ? Thanks
    Jun 2007
    NY State, USA
    Quote Originally Posted by bowhunter195252 View Post
    No, a 14 series will not fit into a 15 series, and vice-versa.
    Answers based on the 2008 & 2011 NEC. If you're on the '14 already I feel sorry for you.
    The L14 is for 125 Volts, and the L15 is for 250 Volts. Obviously, bad things would happen if you plugged a 240 volt equipment into 120 volts, or vice versa, so of course the plugs will prevent this from happening.
    The size and orientation of the blades will change as you progress through the various voltages and amperages. The direction of the tab on the keying terminal will also shift between inward and outward. You either have to know the series and amperage of the receptable to get the proper plug, or take it with you to try the various ones.
