Results 1 to 2 of 2
Thread: Can I encase Under slab 2" ABS In concrete
    DIY Junior Member yyaassoo's Avatar
    Mar 2010
    Idaho
    Default Can I encase Under slab 2" ABS In concrete
    Hello , Im going to back fill a trench in slab . Should I pour in some concrete in the bottom of the trench here and there to hold up the pipe before backfilling trench with dirt ? Also can I encase part of the abs in concrete if I wrap the pipe first ? Thanks Spanky
    Jan 2006
    Rosedale, Md
    To support your pipe use stone, to pour concrete on the pipe make sure it is covered with something; as long as the concrete doesn't touch it.
