Ukrainetz
From the specs sheet it looks like there is 1.25" behind the toilet, suggesting it should fit with a 10.75" rough. Any reason I should not do this? The only thing that I could think of which would be bad, is condensation on the bowl ruining the wall. I've read some posts where people boldly stated that there is a minimum distance between the tank and the wall....anyone know what it is if it indeed exists? I will have to carefully remeasure the rough-in today, but it is roughly in between 10 and 12.
The reason I want to go this route is because the only two 10" toilets I can get locally is a Sterling unit and a Cadet 3. I special ordered the cadet at HD, and it was cracked and used....returned it. I can't afford to waste my time. Local dealer has it in stock, but now its all the way up to $300 with taxes. For an extra $30 I'd much rather get a TOTO. A dealer in NJ has it for $330, and thats roughly the on-line price. I can also get a regular Drake in 10", but it's actually more expensive ($350 or so), and I really like the cyclone flush (ahhh, things that make us happy... ).
Last bit, anyone shop from edigallery.com (NJ) or national builder supply (GA) before?
Thank you for helping out!
