Originally Posted by
Akpsdvan
When flushing out the well from a chlorine treatment, run a hose to some place that does not matter from the pressure tank or the first outside hose bib and then let the water run at 5-6gpm for some 4 hours and that should flush that out, then run the water inside the house for about 30 minutes to flush out the water inside the house.
For me when I do a neutralizer I use a media tank that is at least 10x54 and calcite 1.5 for that size tank, then a control on top say the Fleck 2510 filter valve, there is the same valve for softeners with a few extra parts for the softener part.
Different companies might call it a bit different, but tank, calcite some times with magnesium oxide , backwashing control are the three items that would make up a Nuetralizer.
I am not sure why your filter is loading up so fast, does not sound right, but I am more use to the water here in SouthCentral Alaska.... the iron is below .3 ppm, and normally that should not be a problem... but that is not to say that some thing else could be adding to the fun or that some one put it down as .28 and it should be 2.8ppm now if it is 2.8 or even 28ppm that could really be a challenge when treating the iron.
Any way of getting a second test on that iron to double check?
