Results 1 to 11 of 11
Thread: Drywall Question
    DIY Senior Member Briandl's Avatar
    Feb 2008
    Texas
    Default Drywall Question
    I have drywall which was originally supposed to have a texture sprayed on it, the homeowner changed their mind and now I have a wall that has been painted, however the drywall was never finished smooth. In other words I have lines and what not from where the drywall wasn't sanded because they thought they were going to spray texture over it so it wasn't necessary.
    How do I go about fixing this so I can have a smooth wall?
    TIA!
    It's very tedius to smooth it out over paint, breaking through with sandpaper is much harder than the 'raw' stuff, but it can be done. Whomever painted it before it was prepped properly should pay for it, IMHO.
    quote; Whomever painted it before it was prepped properly should pay for it, IMHO.
    If they were told to prepare it for texture, which is implied in the original question, and priced their installation based on that, then someone decided NOT to texture the wall, why would it be their responsibility? Now, unless the customer painted it themselves, or told the painter to paint it regardless, someone should have at least questioned the surface that was being painted. But even then if they were told to do it, as is,then they would not have any responsibility for additional preparations.
    I don't know if you can make tape seams disappear completely.....but if they are that obvious, then it was a second rate job done in anticipation of texture. That is why texture was invented...to reduce the drywall labor. I think if you want a smooth wall, you have to skim coat the entire wall. I think you can have that done over paint.
    Feb 2008
    Texas
    Well it's not really about who should pay for it as this happened a long, long time ago. It's really more about how it can be fixed now.
    Some of the high end jobs use blue-board which is deisgned to have a thin plaster applied over the whole surface. As noted, I don't know if you could do that over a painted surface, it may not adhere well. But, if it can, this can give you a fantastic, nice, flat wall. Otherwise, it may be easier to just put up say 1/4" drywall over what you have, and start over. Easier than tearing what you have out.
    Feb 2008
    Texas
    That seems far from ideal. I'd imagine I couldn't go over the paint (I believe it's a semi gloss) with a rolled on texture either could I? What options do I have realistically here if I either want a smooth finish, or I'm also willing to roll on a texture?
    I'm not an expert when it comes to plaster but I would probably use some fine grade sandpaper to rough the paint and the areas I was going to repair and plaster right over it. Ideally you would want to plaster a wall with no paint on it, but given that it is a little late for that option I think this is your best alternative if you want a smooth wall.
    -rick
    DIY Junior Member
    Mar 2010
    Escondido, Ca.
    Start with 150 grit sand paper or drywall type ( it looks like window screen). Sand ridges and high spots best you can. If paint is several months or more in age this task will be easier.
    Then hit high spots with 220 grit.
    Wall is now ready for a topping coat to smooth out high and low spots. Use a 8 to 12 inch blade. Minimal material needed. Keep it smooth and let it dry. Once dry sand and your ready for paint or spray texture.
    I'm guessing your not doing a skip trowel look.
    Best regards, NCRC
    Feb 2008
    Texas
    That's basically what my brother told me to do (He said sand it but wasn't specific about what grits to use). However since he doesn't do this for a living I was looking for a second opinion.
    Thanks.
    Anona Jean
    Guest
    wipe the wall with a damp rag to get most of the left behind dust use just one good prime coat without sanding this will work just fine with no worries. it is always good to have a sanding pole with swivel head even if you don't use it every day. it comes in handy when you need to sand a wall or ceiling. make sure the edges of the joint compound is feathered sos thast you don't get any noticing separation lines as the compound tapers down to the wall.
