While the transformer might be bad, it is more likely that there is a different failed component somewhere on the board or that the board drives that is overloading the circuit causing the fuse to blow. The fuse, on a well-designed board, will blow before the whole thing burns up. Unless you're lucky and can identify the part that is bad, you'll probably have to replace the board. Now, depending on how good the schematics are that they provide (often not very complete), and the troubleshooting guide is good, and (that's a lot of ands), you might find something off-board that is bad that is overloading the power supply on the board and blowing the fuse.
