Thread: Swingset update
    DIY Member richrc1131's Avatar
    Apr 2008
    Central Connecticut
    Default Swingset update
    Right now, I have a swingset that rests on grass and worn spots that get muddy every time it rains. I want to remove the grass from around it and fill it with wood chips.
    My question is: is there some material that I have to put down below the wood chip layer such as stone or a barrier of some kind to restrict the regrowth of the grass or will the wood chips be enough?
    Plumber jimbo's Avatar
    Generally, a layer of weedblock fabric would do the trick. This is like a plastic, but it "breathes" and allows water to pass. you get it at HD or any garden shop
    You might want to look into using sand instead of wood chips, far less injuries.
    www.parentcentral.ca/parent/article/738919
    Apr 2008
    Central Connecticut
    Excellent advice. Thank you both.
