Results 1 to 11 of 11
Thread: Air Control Valve
    DIY Junior Member
    Mar 2010
    Kenner
    Default Air Control Valve
    What is a air control valve and what does it do on a bladderless tank? Is it mandatory?
    Previous member
    Jul 2009
    North of the Mason dixon Line
    It maintains the air cusion in the top of the tank and no, it's not strictly mandatory but without it you will have to drain the tank and re-establish the air cusion a couple times a year or more.
    Jan 2008
    There is more than one type of setup. Peter is referring to one that allows air INTO the tank. When the air bleeders are in the well, a float-style AVC works to allow the excess air OUT of the tank.
    Previous member
    Jul 2009
    yes, I forgot those. But nobody has uses that set up around here.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    They are quite common in this part of the country. Most of the wells around here use regular galvanized tanks, probably 2:1 or more. If you see a sub/galvanized tank, it probably has a bleeder.
    Quote Originally Posted by Peter Griffin View Post
    DIY Junior Member
    Mar 2010
    Kenner
    This had a steel tank and whenever the pump shut off it made a little pffft sound. My boss put in a bladder tank and it is getting air probably from the well as I have learned here. I guess we need to go back with a regular tank but I wondered where to buy the float style avc? Where do you get galvanized tanks all I see is steel with epoxy liner?
    DIY Junior Member
    Mar 2010
    Kenner
    What is 2:1 or more mean?
    Jan 2008
    Epoxy lined is the "new and improved" galvanized-style tank.
    The AVC is Grainger part# 7P020 . Probably also available at any good plumbing wholesaler.
    Feb 2010
    SE Texas-Coastal
    Ratio of galvanized tanks to bladder tanks. For every 1 bladder tank in this area there are probably 2 galvanized regular tanks.
    Dec 2009
    northfork, california
    Sears online sells some big glasslined tanks quite cheap.
    Previous member
    Jul 2009
    Funny how they do different things in different parts of the country. Nobody installs non bladder air tanks up here. I have not used one in better than 30 years. Doubt I could even get one from my wholesaler unless I special ordered it.
