Results 1 to 2 of 2
Thread: Help choosing sump pump
    DIY Junior Member
    Sep 2009
    Wheaton, IL
    Default Help choosing sump pump
    Hi everyone, and thanks in advance for the help. I'm looking to replace my sump which is currently a simmer. I have decided on either a hydromatic or a zoeller pump, probably leaning toward the zoeller. Anyhow, when it is wet in the area, the pump will run every minute or so. I have been looking at the m-53 or the possibly the flowmate 98 or DA-1. Since the pump runs often i was thinking it would be best to buy the pump with the greatest on/off difference, which would be the zoeller 98. How does the 98 compare with the m-53 or DA-1? IS there a better solution to increase the on/off difference, i have read about attaching the switch to the outtake pipe. I'm looking for the best pump and to create the best conditions for a long lasting pump.
    Chris
    Dec 2009
    northfork, california
    Check dean bennet supply and Ira Woods. Buy it without the built in float and add a remote one. the 53 is fine.
