Results 1 to 5 of 5
Thread: Air in lines
    DIY Junior Member
    Mar 2010
    geneva il.
    Default Air in lines
    After everytime my water softner recycles I get air in the line. It"s only on the first floor the second floor doesn"t seem to be affected. It takes quite awhile for the air to clear.
    Dec 2009
    Alaska
    Type of softener and Age of softener please.
    Could be the unit is drawing air during a cycle. Check the brine line carefully.
    Dec 2009
    Alaska
    There was a brine float assembly that was out for awhile, still is but the rubber seal at the base of the float arm would go hard and break, letting air in and way to much water in the brine tank..
    That float was plastic with 1/2" nut on the pickup tube and 3/8" on the brine line.. it is a copy of the Fleck 2310 saftey float..
    DIY Junior Member Bob Fader's Avatar
    May 2010
    Willmar,Mn
    Default air in line
    If this is a Sears, Eco. Linsay. Northstar, or a Morton it is the float under the float! Autotrol valve check the sheck in the glass bowl.
