Thread: 2 inch vs 1.5 trap for kitchen sink
    DIY Senior Member bbillcee's Avatar
    Feb 2007
    NY
    Default 2 inch vs 1.5 trap for kitchen sink
    i have a 2 inch pvc 90 stubbed out under the sink....i was planning to install a 2 inch trap then use a 2 in to 1,5 reducer to connect to the tail piece
    or would it be better to put an a 2 inch adapter at the 90 and use a 2 to 1.5 inch lock nut and step it down and use 1.5 for everything
    which would be the better job?
    Default drain
    Neither way is necessarily "better" and both are equally adequate. Because of the long term benefits, I would use the reducer on the 2" and 1 1/2" tubing for the rest of the drain installation.
    Feb 2007
    NY
    thanks HJ i just though maybe the 2 inch would having things flowing better...the 2 gal i replaced was down to about 3/4 with all the build up
