Neither way is necessarily "better" and both are equally adequate. Because of the long term benefits, I would use the reducer on the 2" and 1 1/2" tubing for the rest of the drain installation.
i have a 2 inch pvc 90 stubbed out under the sink....i was planning to install a 2 inch trap then use a 2 in to 1,5 reducer to connect to the tail piece
or would it be better to put an a 2 inch adapter at the 90 and use a 2 to 1.5 inch lock nut and step it down and use 1.5 for everything
which would be the better job?
