Mach-0
The stopper that plugs the bathtub drain is frozen and will not budge. It is almost completely in the completely plugged position but will allow water to drain out very slowly. The lever will not budge. I took out the screws and tried to remove the mechanism with vice grips -- no luck. I tried to tap the plug down with a flexible fiberglass rod to break it free and no luck there either. Any suggestions?
