Scott Home Owner
Hi, and thanks for pondering my question. My summer water bill is astronomical. I'm thinking of installing a pump that will take water from the sump basin and move it to several (connected) 55 gallon plastic drums. Then I can use the collected water for our flower gardens! Brilliant - right?
Well, the total vertical distance (from the bottom of the sump basin to where water would empty into the top of one of the barrels) is about 15'. The distance of the PVC pipe run will be about 50'.
Obviously the sump does not always have water in it, and when the barrels are full the pump should shut off. So, I'm thinking of putting two water level switches (one on each end) so if the barrels can hold more AND if there's water in the sump, the pump will go on!
OK, here's my dilemma - I know too little about pumps and I don't know what specifications my pump should have. Based on what I've read online (and assuming my measurements are correct), I need a pump with greater than 20' of head - right? Then, I envision my pump turning on, the sump basin quicky emptying out, and no water getting to my barrels. (I will install a check valve to assist in this matter).
I thought, maybe I should get a pump that can lift water high and provide low flow.
Obviously I don't know what I'm doing, and maybe (as my wife always tells me), I'm overthinking this.
Do you have any thoughts that might help me?
