eldyfig
Ok, another update. I didn't lose any resin during the last regen was because the drain was plugged with resin from the preceding regen. So I go ahead and pull the rubber orifice out of the drain port so the resin there can be rinsed out during a backwash. I manually started a regen. The backwash started fine and the water coming out the drian port was clear for about 15 seconds. However, before I was able to get the orifice back in, a bunch of resin shot out of the drain. I cut the water off to the softener, rinsed the drain port, reinstalled the orifice and drain hose and then turned the water back on to continue the backwash. At this point, no more resin was coming out. The backwash continued without incident.
I now only have approximately 17" of resin in the tank and 24" of headroom. I think I am just going to open the softener, dump whatever is in there, and inspect the distributor tube. I guess I will start looking for some resin. Any suggestions?
