Davebutch
I recently installed a new Toto Drake two-piece elongated toilet and followed the directions provided in a posting on this forum (excellent instructions, by the way). At first, there seemed to be a leak around the bolt that holds the tank to the bowl on the left side. After contacting Toto, they suggested I take the tank off, snug the bolts on the tank, fill the tank with water, and see where the leak was coming from. I did that and there were no leaks in 24 hours. I put the tank back on, and the leak is still there. It only occurs, though, when the toilet has been flushed, so I'm thinking there is a leak around the rubber gasket between the tank and bowl. The rubber gasket looks fine (it's brand new, after all), and it's not possible to see in that area once the tank is bolted to the bowl. Does anyone have any suggestions as to what I should look at next?
